You’re talking about de-de
but your screenshot shows en-us
which has no translations yet.
You have to translate these - see: Knowledge Base — Zammad (for Agents) documentation
MaxG
June 7, 2022, 3:39pm
3
I get the point that the entries are not translated.
But no matter which language i chose, all Knowledge Base entries are gone. Even in the standard language we used they are not showing up…
You may be lucky by running zammad run rails r "Cache.clear"
if you’re on a package installation.
Hard to tell as you didn’t provide that information.
While we’re at that, please upgrade to Zammad 5.1 as 5.0 is prune to security issues.
system
Closed
October 5, 2022, 4:05pm
5
