Used Zammad installation source: (source, package, …) apt
Operating system: Ubuntu 16.04 LTS
Browser + version: Chrome
i would like to use the knowledge Base. It is possible to configure in admin settings, but i can´t open the knowledge base. I think i dont understand the custom url configuration.
My Helpdisk is ticket.domain.de with nginx. If i understand custom url, i enter /help und get the webserver configuration. I have been integrated this 2 lines into /etc/nginx/sites-available/zammad.conf. But i can´t open the knowledge base with ticket.domain.de/help, browser run´s into timeout. What is the correct custom url configuration?
Please remove your 2 extra lines from nginx-configuration you added (whatever they are…) as by default, the rails route is /help - so frankly: You’ll already be able to access /help.
If that doesn’t help, please provide:
access/error log of nginx from the moment you’re trying to call the troublesome URL
zammad-production log of the exact same moment
configuration file of nginx
configuration of your Knowledge Base (especially the custom URL is interesting here)
Started GET “/help” for 95.90.214.243 at 2019-06-10 14:54:38 +0200
I, [2019-06-10T14:54:38.743767 #7511-47092960140220] INFO – : Processing by KnowledgeBase::Public::CategoriesController#forward_root as HTML
I, [2019-06-10T14:54:38.754140 #7511-47092960140220] INFO – : Redirected to http://ticket.DOMAIN.de/help/en-us
I, [2019-06-10T14:54:38.756032 #7511-47092960140220] INFO – : Completed 302 Found in 12ms (ActiveRecord: 3.5ms)
configuration of zammad nginx:
this is the nginx config for zammad
upstream zammad {
server localhost:3000;
upstream zammad-websocket {
server localhost:6042;
ssl_certificate /etc/letsencrypt/live/ticket.DOMAIN.de/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/ticket.DOMAIN.de/privkey.pem; # managed by Certbot
include /etc/letsencrypt/options-ssl-nginx.conf; # managed by Certbot
ssl_dhparam /etc/letsencrypt/ssl-dhparams.pem; # managed by Certbot
custom url:
acutally nothing, before your post /help
upstream zammad {
server 127.0.0.1:3000;
server 127.0.0.1:6042;
Or ensure that localhost always resolves to 127.0.0.1
The error should be gone from what I can see, as production log says it’s shipping the help page. If not maybe it’s nginx or something working BEFORE your server
