Knowledge Base Article Review
We are working very intensively with the knowledge base as it replaces our user manual. I would like the database to be equipped with a review function that allows me to set a date for a resubmission and then check the article for up-to-dateness and correctness.
I envision this function as follows: Under the tag section, a new section “Review by” is created with a dropdown menu in which I can select “6M, 12M, 18M and 24M”. The time period is then added to the last edited date and when this date is reached, a notification is sent to the editors asking them to review the article. In the period from when the review date is reached until the article is reviewed, a note “Article may be out of date and is scheduled for review” should be displayed in the article. If I then edit or save the article, the review date is extended again by the set interval.
It would also be great if not only the publication date but also the last edited date were displayed in the article.
Best Regards,
Daniel
Responding because I’m also interested in knowing if this ever gets implemented.
