Hi team I need help from you regarding SAML integration.
given properly IDP SSO TARGET URL and IDP SINGLE LOGOUT TARGET URL and IDP CERTIFICATE
but also getting error .
Error message and Zammad version would be a starter.
I followed this document SAML — Zammad documentation
Make sure to set the FQDN and HTTP type correctly (so the way you use it in your browser) to match the callback URL of your keycloak instance. Otherwise you’ll have a configuration mismatch and won’t be able to authenticate correctly.
