Issues with email sent on escalation
  • Used Zammad version: 6.3.1
  • Operating system: Debian
  • Browser + version: Chrome
Create a trigger to send an email when a ticket escalates
Email is sent multiple times (2 or 3 times) each 5 minutes apart.
  1. Create an SLA with 15 min on update time:
  2. Create a trigger to send an email on escalation (Used the created at trying to avoid it to be sent multiple times and leaving it time to be sent 1 time):
  1. It will trigger up to 3 times before the 30 min is reached:
I am not sure why this is happening, tried also putting Escalation_at has changed along with Escalation_at has reached but it stopped working at all. Does anyone know how can I set this up to be only sent one time once escalation time is reached?
Best Regards,
You may have to use clauses to ensure that the trigger runs exactly once. If the agents are the recipients, I’d suggest to use the already builtin notification instead. It should by default already mail your agents.
Escaping these clause can be achieved by e.g. using tags.
