Issues with elasticsearch after upgrading from 7 to 9
  • Used Zammad version: 7.01-1776088456.8a5307eb.bullseye
  • Operating system: Debian 11
  • Browser + version: Chrome Browser
  • Start elasticsearch without error
  • systemctl status elasticsearch.service
    ● elasticsearch.service - Elasticsearch
    Loaded: loaded (/lib/systemd/system/elasticsearch.service; enabled; vendor preset: enabled)
    Active: failed (Result: exit-code) since Mon 2026-04-13 18:56:29 EDT; 1s ago
    Docs: https://www.elastic.co
    Process: 409 ExecStart=/usr/share/elasticsearch/bin/systemd-entrypoint -p ${PID_DIR}/elasticsearch.pid --quiet (code=exited, status=1/FAILURE)
    Main PID: 409 (code=exited, status=1/FAILURE)
    CPU: 15.584s
Apr 13 18:56:08 zammad-22.pbzinc.loc systemd[1]: Starting Elasticsearch…
Apr 13 18:56:28 zammad-22.pbzinc.loc systemd-entrypoint[409]: ERROR: Elasticsearch did not exit normally - check the logs at /var/log/elasticsearch/elasticsearch.log
Apr 13 18:56:29 zammad-22.pbzinc.loc systemd-entrypoint[409]: ERROR: Elasticsearch died while starting up, with exit code 1
Apr 13 18:56:29 zammad-22.pbzinc.loc systemd[1]: elasticsearch.service: Main process exited, code=exited, status=1/FAILURE
Apr 13 18:56:29 zammad-22.pbzinc.loc systemd[1]: elasticsearch.service: Failed with result ‘exit-code’.
Apr 13 18:56:29 zammad-22.pbzinc.loc systemd[1]: Failed to start Elasticsearch.
Apr 13 18:56:29 zammad-22.pbzinc.loc systemd[1]: elasticsearch.service: Consumed 15.584s CPU time.
zammad-22:/# cat /etc/elasticsearch/certs/http_ca.crt | zammad run rails r ‘SSLCertificate.create!(certificate: STDIN.read)’
  • I recently upgraded elasticsearch from 7 to 9. I ran zammad run rake zammad:searchindex:rebuild
  • rake aborted!
    Unable to process GET request to elasticsearch URL ‘https://localhost:9200’. Elasticsearch is not reachable. It’s possible that it’s not running. Please check whether it is installed.
Response:
#<UserAgent::Result:0x00007f5fb720aeb8 @success=false, @body=nil, @data=nil, @code=0, @content_type=nil, @error=“#<Errno::ECONNREFUSED: Failed to open TCP connection to localhost:9200 (Connection refused - connect(2) for "localhost" port 9200)>”, @header=nil>
Payload:
null
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:49:in ‘SearchIndexBackend.info’
/opt/zammad/lib/tasks/zammad/search_index_es.rake:64:in ‘block (3 levels) in ’
/opt/zammad/vendor/bundle/ruby/3.4.0/gems/rake-13.3.1/exe/rake:27:in ‘<top (required)>’
/opt/zammad/bin/bundle:121:in ‘Kernel#load’
/opt/zammad/bin/bundle:121:in ‘’
Tasks: TOP => zammad:searchindex:rebuild => zammad:searchindex:version_supported
Zammad 7 is accessible from the web URL, however, even though I have users, I can’t search for them when changing customer on a ticket.
I am also trying to reset the elasticsearch user password without success /usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic
ERROR: Failed to determine the health of the cluster., with exit code 69
Your Elasticsearch isn’t even running (state: failure).
Check the logfile of ES ( /var/log/elasticsearch/elasticsearch.log), as the traceback suggests.
[2026-04-13T18:32:52,503][ERROR][o.e.b.Elasticsearch      ] [zammad-22.pbzinc.loc] fatal exception while booting Elasticsearch
java.lang.IllegalArgumentException: Unknown properties for plugin [ingest-attachment] in plugin descriptor: [type]
        at org.elasticsearch.plugins.PluginDescriptor.readFromProperties(PluginDescriptor.java:203) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.plugins.PluginsUtils.readPluginBundle(PluginsUtils.java:256) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.plugins.PluginsUtils.findBundles(PluginsUtils.java:237) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.plugins.PluginsUtils.getPluginBundles(PluginsUtils.java:219) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.plugins.PluginsLoader.loadPluginsBundles(PluginsLoader.java:160) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.bootstrap.Elasticsearch.initPhase2(Elasticsearch.java:227) ~[elasticsearch-9.3.3.jar:?]
        at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:99) ~[elasticsearch-9.3.3.jar:?]
I see this error
for now I restored the vm back to Zammad 6.5. Will review elasticsearch upgrade process a bit more closely,
These are my personal notes while planning to upgrade from 7 to 9, i tested it on my staging system
DISCLAIMER: NO WARRANTY
Overview
Upgrading from 7.17 to 9.3.1 requires two major upgrades. Each major upgrade must be prepared and executed independently, although the planning phase can be shared.
  1. 7.17.x → 8.19.xThis brings the cluster onto the latest supported 8.x release, which is the required intermediate version before upgrading to 9.3.1.Before running this upgrade, all ingest components and client libraries must be upgraded to 7.17.x.
  2. 8.19.x → 9.3.1This completes the upgrade to the latest 9.x release.Before running this upgrade, all ingest components and client libraries must be upgraded to 8.19.x.
1) Upgrade to 7.17.29 (from any 7.x)
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.17.29-amd64.deb
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-7.17.29-amd64.deb.sha512
shasum -a 512 -c elasticsearch-7.17.29-amd64.deb.sha512
sudo dpkg -i elasticsearch-7.17.29-amd64.deb
ensure ES is stopped before touching plugins
sudo systemctl stop elasticsearch
sudo systemctl daemon-reload
7.x: ingest-attachment IS a plugin → must match ES version
sudo /usr/share/elasticsearch/bin/elasticsearch-plugin remove ingest-attachment || true
sudo /usr/share/elasticsearch/bin/elasticsearch-plugin install ingest-attachment
sudo systemctl start elasticsearch
2) Upgrade to 8.19.12
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-8.19.12-amd64.deb
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-8.19.12-amd64.deb.sha512
shasum -a 512 -c elasticsearch-8.19.12-amd64.deb.sha512
sudo dpkg -i elasticsearch-8.19.12-amd64.deb
IMPORTANT: remove any old plugin leftovers (7.x plugin dir must not remain)
sudo rm -rf /usr/share/elasticsearch/plugins/ingest-attachment
sudo rm -rf /usr/share/elasticsearch/plugins/.installing-*
3) Upgrade to 9.3.1
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-9.3.1-amd64.deb
wget https://artifacts.elastic.co/downloads/elasticsearch/elasticsearch-9.3.1-amd64.deb.sha512
shasum -a 512 -c elasticsearch-9.3.1-amd64.deb.sha512
sudo dpkg -i elasticsearch-9.3.1-amd64.deb
sudo mv /var/lib/elasticsearch /var/lib/elasticsearch.bak
sudo mkdir /var/lib/elasticsearch
sudo chown -R elasticsearch:elasticsearch /var/lib/elasticsearch
4) Generate Password for Zammad
sudo /usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic
5) Set Elastichsearch Password for Zammad on zammad-web
Now you need your password which was shown during the installation.
Set Elasticsearch user:
sudo zammad run rails r “Setting.set(‘es_user’, ‘elastic’)”
Set Elasticsearch password. Replace <password> with the one you got during the installation of Elasticsearch. In case you need to create a new password, run /usr/share/elasticsearch/bin/elasticsearch-reset-password -u elastic.
sudo zammad run rails r “Setting.set(‘es_password’, ‘’)”
sudo zammad run rake zammad:searchindex:rebuild[4]
sudo zammad run rails r "Setting.set(‘es_attachment_ignore’,\
[ ‘.png’, ‘.jpg’, ‘.jpeg’, ‘.mpeg’, ‘.mpg’, ‘.mov’, ‘.bin’, ‘.exe’, ‘.box’, ‘.mbox’ ] )"
sudo zammad run rails r “Setting.set(‘es_attachment_max_size_in_mb’, 50)”
Thanks for providing these steps. I’ll try them out over the next week or so. I appreciate it.
When I upgraded from version 7 to version 9, I simply uninstalled ES7 completely and then installed ES9 from scratch.
Yes, you will need to rebuild the search index, but you would need to do that when upgrading Zammad to 7.0 anyway.
The ingest-attachment plugin is no longer needed in ES8 and ES9. It’s included in the base version of Elasticsearch.
Thanks for this method.
Thanks @skip for your solution. I was able to do an in-place upgrade of elasticsearch.
For whoever finds this, upgrading is also possible without data loss - especially, if Zammad is not the only thing stored in ES.
Or just the gist with the steps: https://gist.not-enough.coffee/MrGeneration/314462b937b949f783b922e8db6aa76c
