Issue with zammad webhooks and latency when using external automation scripts
Hi everyone, I
’ve been working on a custom integration for our Zammad instance to help automate some of our repetitive support ticketing, but I’ve run into a frustrating performance issue. We are trying to push real-time data from a local environment into Zammad via the REST API, but I’m seeing a significant delay in ticket creation whenever my background automation is running at a high frequency.
I actually started looking into how other high-performance environments manage their execution threads after reading a guide at regarding their optimization for rapid data flow. I’ve been trying to see if the logic used for blox fruit scripts to keep execution stable on a local machine could be adapted to my Zammad workflow, as I suspect my local script is hitting a rate limit or causing a memory leak that slows down the Ruby on Rails background workers. You can see the kind of rapid-fire script execution I’m talking about over at , and it made me wonder if Zammad’s “Scheduler” is particularly sensitive to these types of external executors.
I’m also seeing a related problem where the “Elasticsearch” index doesn’t seem to update immediately when a ticket is created via the script, making it impossible for our agents to search for those new tickets for several minutes. Has anyone else noticed if running script-heavy environments alongside a self-hosted Zammad instance causes the “Nginx” buffer to overflow? I’ve already tried increasing my client_max_body_size and adjusting the database.yml pool settings, but the intermittent timeouts persist. Is there a way to prioritize the Zammad API thread so these background executors don’t cause a “Connection Refused” error, or should I be looking into a more robust message broker like Redis to sit between my scripts and the API? I’d really appreciate any advice on keeping the ticketing system snappy without sacrificing my automation tools!
Did you follow the Docs on the minimal hardware setup?
And if not done so have a look a the performance optimisation options:
If it just happens at high frequency then your server process are moste likely OL in some form.
Or if you use the search in Zammad, it is done via Elasticsearch.
So have a look there maybe too, for example if Elastic starts swaping this could explain this.
But the elastic guys have there own docs on this topic:
