Issue with mobile version - wss://domain.xyz/cable not found
Info about my software stack:
  • Used Zammad version: 6.4.1-1742994139.560f34ed.noble
  • Operating system: Ubuntu 24.04.2 LTS
  • Browser + version: Mozilla Firefox 136.0.3 (but that does not matter, the issue occurs in any browser, on desktop or mobile)
I built my Zammad instance on the registered domain (in example https://fqdndomain.xz/), which is proxied via Cloudflare with websockets enabled. On the server side I have Nginx Proxy Manager, to which is pointed the connection from Cloudflare. On the Nginx Proxy Manager is situated proxy host with websockets support enabled, pointing to my server with Zammad instance, which is behind NAT. It’s a fresh install on newly installed OS with Nginx as a main webserver with default recommended settings. On the local server I have SSL enabled via self-signed certificates, on the NPM I have SSL enabled with LE certificates and on the Cloudflare there is SSL enabled via their/Google certs. So the complete connection chain is secured via SSL.
Mobile version on the URL https://fqdndomain.xz/mobile should work without any issues with all websocket connections included (i.e. action cable).
If I open the Zammad in desktop web UI, everything works as it should (with successful wss connections upgrade (code 101)). But if I open mobile version on URL https://fqdndomain.xz/mobile, I get the error "The connection to the server was lost " displayed on top right of the screen.
When I open developer settings, I see there GET error ā€œ404 Not Foundā€ in regards the GET wss://fqdndomain.xz/cable.
When I try to curl http://127.0.0.1:3000/cable on the server side, I get ā€œPage not foundā€ error too.
I don’t know if the issue happen when you install new instance without Cloudflare or Nginx Proxy Manager. So my steps to reproduce the behavior is place Zammad behind the Nginx Proxy Manager and try to open https://fqdndomain.xz/mobile URL.
I don’t think the issue is happening because some incompatibility between Cloudflare, Nginx Proxy Manager and local webserver, because as I wrote above, I have enabled websocket support everywhere and if I open the web UI in desktop mode, I normally get 101 codes from GET wss://fqdndomain.xz/ws URLs.
Here is my proxy settings from the local Nginx webserver:
location /ws {
proxy_http_version 1.1;
proxy_set_header Connection ā€œUpgradeā€;
proxy_read_timeout 86400;
location /cable {
location / {
proxy_set_header X-Forwarded-User ā€œā€;
proxy_read_timeout 180;
gzip on;
gzip_proxied any;
Alright, I was too fast with writing the post and I didn’t try one thing before that - just one reboot of the server. When I rebooted it, mobile UI works with connections on wss://fqdndomain.xz/cable succesfully upgraded (code 101). It’s just kind of magic for me because I didn’t change any configuration before the reboot.
So the issue is self-resolved now.
Iā€˜ll just guess that you just forgot to reload your nginx on the Zammad server after adjusting the configuration.
Nice guess, but no - of course I reloaded nginx several times just because I tried to tune it a bit if something help, but with no effect, until the reboot of everything. Sometimes the question ā€œhave you tried to turn it off and on again?ā€ is in the right place.
