Hi All,
Looking at the Zammad code I see several models using class variables, which are not thread safe.
If the application server is not multi thread I think that there is no problem, but if Puma is used as the application server could occur a race condition, when two or more threads try to access the same class variable, am I correct? If not, what am I missing out on this?
Hi @thorsteneckel, yes I can give you an example. I pulled Zammad from github, master branch, and used the Scheduler model to do test.
Scheduler uses the class variable @@jobs_started to keep track of the jobs. In non multithread environment I think there is no problem because this variable is exclusive to the process started by the application server. But Puma starts a new thread for each request in the same process, so the variable is shared among them. To simulate that behaviour I started a rails console and used the below code:
We can see that the object id of the variable is the same, thread 1 changes the hash to 11 and sleeps to allow thread 2 to change it to 22, at the end thread 1 puts the hash value and it was changed to 22. So, the variable is shared among threads in the same process. I didn’t test other models, but I see class variables in Setting and Channel.
Hash is also not thread safe, and the variable is a hash. I don’t know what would happen if the two codes below, extracted from Scheduler.rb, were executed at the same time in two threads:
def self.threads
@@jobs_started[ job.id ] = start_job(job) <= This code in one thread
end
def self.skip_job?(job)
thread = @@jobs_started[ job.id ]
return false if thread.blank?
# check for validity of thread instance
if !thread.respond_to?(:status)
logger.error "Invalid thread stored for job '#{job.name}' (#{job.method}): #{thread.inspect}. Deleting and resting job."
@@jobs_started.delete(job.id) <= This code in another thread
return false
end
end
This is the reason why I put this question. I think it is very difficult to identify this kind of situation in production. Please, correct me if I am missing something.
Hi @josefsmvm - you’re right about this. At least partially: These wouldn’t be thread safe. However, the scheduler is running in a separate process - outside of puma. These variables are on purpose not thread safe (to manage the running jobs by the scheduler dispatcher).
