I am currently evaluating Zammad in a test environment before deploying a production installation using the official Docker deployment and Exchange Online.
Environment:
- Zammad version: 20260703070405
- Installation type: Package installation
- OS: Ubuntu Server 24.04 LTS
- Elasticsearch 8.19.x
- Mail provider: Gmail
- IMAP: imap.gmail.com (SSL, port 993)
- SMTP: smtp.gmail.com
- Single inbound Gmail channel
- Single outbound Gmail channel
Issue description:
I am experiencing very inconsistent email fetching behavior.
The strange part is that everything appears healthy:
- IMAP connection is green
- SMTP connection is green
- Email account is active
- Zammad worker is running
- Elasticsearch connection is working
- Search index rebuild completed successfully
- Monitoring shows no errors
Symptoms:
Sometimes incoming emails create tickets immediately.
Sometimes the first emails are completely ignored.
Example:
- Email #1 → not imported
- Email #2 → not imported
- Email #3 → imported
- Afterwards emails #4, #5, #6 are imported normally
In another test:
- Email #3 → not imported
- Email #4 → not imported
- Email #5 → imported
- Afterwards email processing started working normally.
The behavior is not reproducible based on sender address or ticket state.
Additional observations:
When a ticket is not created automatically, running:
Channel.fetch
from Rails console often imports the email immediately.
However, I have also seen cases where timing seems relevant:
- Email arrives in Gmail Inbox
- Immediate Channel.fetch imports the email successfully
- Waiting some time and then running Channel.fetch may result in “no message”
The email remains visible in Gmail Inbox.
Production log examples:
Successful fetch:
- fetching imap (…)
- message 1/1
- Process email with msgid …
- Ticket created
Unsuccessful fetch:
- fetching imap (…)
- no message
even though the email is visible in Gmail Inbox.
Temporary workaround:
I created a script that executes:
Channel.fetch
every 10 seconds.
With this workaround:
- 5/5 emails imported
- 10/10 emails imported
- No missing tickets observed
Questions:
- Has anyone seen similar behavior with Gmail IMAP?
- Is there a known issue affecting automatic fetching while manual Channel.fetch works reliably?
- Is there a way to increase logging/debugging for the IMAP fetch process?
- Are there any known fixes in Docker deployments or newer versions?
This is currently only a testing environment. Before moving to Docker + Exchange Online in production, I would like to understand the root cause.
Thank you!
