I currently run a website which is built on CodeIgniter and uses Firebase for user management. I would like to use a helpdesk tool that allows my customers to submit tickets without having to create a different account within the helpdesk platform (currently using HelpRace by the way, in which users have to create a separate account which is awful).
Would this be possible with Zammad?
Thank you very much for your time.
Diogo
I set this to Technical Assistance, as this is more fitting, hope you don’t mind.
Yes SSO is possible. The following github post might lead you in the correct direction:
opened 09:39AM - 20 Jun 17 UTC
closed 05:46PM - 30 Sep 19 UTC
enhancement
documentation
authentication
verified
prioritised by payment
Hi there - thanks for filling an issue. Please ensure the following things… before creating an issue - thank you! 🤓
### Infos:
* Used Zammad version: latest
* Used Zammad installation source: rpm
* Operating system: CentOS 7
* Browser + version: Firefox latest
This is a question regarding Single Sign On. We are using a Microsoft Active Directory in our company and the login works fine with ldap-sync.
Im wondering if SSO would be possible. I already tried to set it up using nginx, but it just won't work :-(
Is there an easy way to do it? Maybe one of you already set up Zammad with SSO? Would be nice if someone has an instruction or some examples how to implement it.
Thank you in advance.
Other than that Zammad offers a powerful API and the option to add authentication prodivers.
That’s great Mr. Generation, thanks!
What about a Knowledge Base? Any idea when/if this will be implemented?
KB will be coming in Q4, I guess that this will not happen before the middle of Q4 - but maybe the devs are faster.
Good to know, thanks!
One last question: Do you know if there’s any guide for installing Zammad on a server with DirectAdmin (without breaking it)?
Sorry, but that’s out of my scope I can assist you with. The Featurelist isn’t giving me a hint if proxy-server creation is supported. If not you can proberbly forget about it.
Alright, thanks! We’ll look into the best way to install Zammad on our servers!
system
Closed
December 30, 2018, 2:52pm
8
