Installing on a shared hosting
Is it possible to install Zamad on a shared hosting and are there any guides on how to achieve that?
Thanks.
No this will not be possible.
You need root-rights and ssh access to the server you want to run zammad on.
Usually this is not the case on shared hosting-machines.
Also, please keep the system requirements in mind.
https://docs.zammad.org/en/latest/prerequisites-hardware.html
