Installation SMTP parameter: 501 Syntax error in parameters or arguments
  • Used Zammad version: latest from docker
  • Used Zammad installation type: portainer
  • Operating system: Ubuntu 22.04 LTS
  • Browser + version: Firefox 131.0.2.
Check sending e-mail via smtp
Run installation as described
Same here. Used the docker-compose stable version.
If I add the same mailbox at email acounts it works. At email notification I get the 501 error.
Hi @sprickw, hi @Hellsfoul.
Do you have some log information available, containing a traceback etc. to be able to understand what happened?
Hi fliebe92,
thank you for your reply. I watched a video yesterday and saw, that the person changed in the email settings of zammad at notification-sender the string <noreply@#{config.fqdn}> to the actual email adress.
Now it worked to add the smtp settings of my mail provider.
Can you provide a link to this video?
Sure!
I just followed the installation documentation and hit the wall quiet early. When trying to install by portainer, where could I find logs that can be of help?
Hi @sprickw. I guess you need to check the logs of the railsserver container.
Here is the video: https://www.youtube.com/watch?v=AjIoNgyOCe0
EMail configuration starts at minute 15:00 and the step, where he changes the replyto, which fixed the problem for me, starts at 16:20
