- Used Zammad version: 2.7
- Used Zammad installation source: https://github.com/zammad/zammad-docker-compose
- Operating system: Ubuntu 16.04
- Browser + version: Chrome 70.0.3538.77
- Successfully access to https://my-domain
- The site can’t be reached. my-domain refuse to connect
Install Zammad on docker
Successfully run on port 80
Create a self-certificate on nginx in host (ubuntu)
Open port 443, add certificate to my-domain
Test and run: ok
Config in docker: config zammad-nginx by edit file /zammad-docker-compose/kubernetes/30_configmap_nginx.yaml:
Add the following line:listen 443 ssl http2; listen [::]:443 ssl http2; server_name support.newtel.vn; ssl_certificate /opt/zammad/support.newtel.vn.crt; ssl_certificate_key /opt/zammad/support.newtel.vn.key; ssl_protocols TLSv1.2 TLSv1.1 TLSv1;
Config container zammad-docker-compose_zammad-nginx_1 : use port 443
Run zammad docker, access to zammad through my-domain:443 and the site refused to connect
How can I open port 443 in zammad docker?
Thank you very much
