incoming customer messages sent through telegram should always reflect in the ticket
incoming customer messages are intermittently shown in the ticket
the ticket doesn’t show all customer messages, even though they are shown in the customer’s telegram app
the behaviour seems quite random, sometimes messages appear, other times they don’t…
Below is an extract from the production.log file which implies the message was received successfully but the text never appears in the ticket?
I, [2018-07-25T12:38:25.693754 #883] INFO -- : Started POST "/api/v1/channels_telegram_webhook/TzRp_srcu-D3YQ?bid=434497675" for 149.154.167.212 at 2018-07-25 12:38:25 +0200
I, [2018-07-25T12:38:25.699465 #883] INFO -- : Processing by ChannelsTelegramController#webhook as HTML
I, [2018-07-25T12:38:25.699607 #883] INFO -- : Parameters: {"update_id"=>267510493, "message"=>{"message_id"=>25, "from"=>{"id"=>96232693, "is_bot"=>false, "first_name"=>"Bruce", "language_code"=>"en-gb"}, "chat"=>{"id"=>96232693, "first_name"=>"Bruce", "type"=>"private"}, "date"=>1532515105, "text"=>"Here is a message"}, "bid"=>"434497675", "callback_token"=>"TzRp_srcu-D3YQ"}
I, [2018-07-25T12:38:25.714260 #883] INFO -- : Completed 200 OK in 15ms (Views: 0.2ms | ActiveRecord: 5.9ms)
Setup a telegram bot and add it to Telegram via the API
Send a message to the bot via telegram
A new ticket is opened
Reply to the customer
The customer send’s a reply back
It is random if the customer message is shown in the ticket or not…
