I can’t import the Organization (organization_id) from LDAP. Would be nice if I could add that field.
Or is there a workaround?
Technically you could map those fields - but you’d need to have your organization ID within your ldap. You normally don’t, but have the organization name. So that won’t work for you I guess.
You might want to use domain based assignment, but need to ensure that the organization is there before you create your user(s).
Yep… before
So I tried to delete some user and do the sync again. Didnt find the delete button, googled…
→ Ability of deleting customers and / or all ticket at once. · Issue #2074 · zammad/zammad · GitHub
The name would be fine because I have that in my LDAP (6 different companies here)… I think I will try to delete them in the Database and start over again. I dont want to choose the Organization for 500+ Users by hand
I strongly suggest not to “fiddle around in your database”.
I suggest this thread, it might be tastier:
A trainee had to do it by hand
safest way.
thx for your help
