Implement an admin function to disable merging of tickets
it would be great if admins could control the visibility of the Merging Tickets feature globally and/or per group.
Globally as part of the /#settings/ticket admin section with a new tab called Merging where they can control it with a switch and define exceptions and a merging text.
Per Group as part of the /#manage/groups admin section with a dropdown field only visible if globally active (see option above). The options should be active and inactive.
Reasons:
  • as the merging of Tickets is an advanced and irreversible feature misused by a lot of agents
  • some groups may have content that is critical and should never be merged or misused by merging into a wrong ticket
  • some groups may still need the merging options, even if others don’t (control by group)
  • some agents cannot get it how to use merging tickets even though the group needs it (option to exclude agents from ever using it)
  • the current message “merged” displayed after the ticket has been merged is not enough descriptive (option to write a custom message in order to solve the Notiz bei Ticketzusammenfassung zu dĂĽrftig · Issue #832 · zammad/zammad (github.com))
Sorry if I defined the feature request wrong, it’s my first one.
Best regards,
Mario
I would suggest that the option should be placed under Settings - Ticket instead of a separate item.
Just adding to you in my opinion clear feature request.
Looking forward to see what other reactions will be.
Best regards
Thank you for your support.
It doesn’t make a big difference for me, but if all features are implemented it would be worth the new tab. If someone “just” implements the on/off switch, then of course as part of the Ticket tab.
I’ve never used Ruby and therefore don’t have time to implement it by myself. Looking forward to reduce frustration about wrongly merged tickets :smile:
