- Used Zammad version: 3.3
- Operating system: CentOS 8
- Browser + version: Any
- emails could be received
Production Log:
(eval):1:in `_start_job'
/opt/zammad/app/models/scheduler.rb:287:in `eval'
/opt/zammad/app/models/scheduler.rb:287:in `_start_job'
/opt/zammad/app/models/scheduler.rb:239:in `block (2 levels) in start_job'
/opt/zammad/app/models/scheduler.rb:237:in `loop'
/opt/zammad/app/models/scheduler.rb:237:in `block in start_job'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/logging-2.2.2/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
I, [2020-03-23T03:33:22.862446 #10121-70334931321340] INFO -- : ended Channel.fetch took: 0.044817488 seconds.
I, [2020-03-23T03:33:31.012675 #10121-47387577075200] INFO -- : Scheduler running...
I, [2020-03-23T03:33:31.018686 #10121-47387577075200] INFO -- : Running job thread for 'Import OTRS diff load' (Import::OTRS.diff_worker) status is: sleep
I, [2020-03-23T03:33:31.018743 #10121-47387577075200] INFO -- : Running job thread for 'Process escalation tickets' (Ticket.process_escalation) status is: sleep
I, [2020-03-23T03:33:31.018777 #10121-47387577075200] INFO -- : Running job thread for 'Check Channels' (Channel.fetch) status is: sleep
I, [2020-03-23T03:33:31.018804 #10121-47387577075200] INFO -- : Running job thread for 'Generate Session data' (Sessions.jobs) status is: sleep
I, [2020-03-23T03:33:31.018830 #10121-47387577075200] INFO -- : Running job thread for 'Check streams for Channel' (Channel.stream) status is: sleep
I, [2020-03-23T03:33:31.018997 #10121-47387577075200] INFO -- : Running job thread for 'Execute jobs' (Job.run) status is: sleep
I, [2020-03-23T03:33:52.867527 #10121-70334931321340] INFO -- : execute Channel.fetch (try_count 0)...
I, [2020-03-23T03:33:52.868963 #10121-70334931321340] INFO -- : fetching imap (Host/User port=993,ssl=true,starttls=false,folder=Zammad,keep_on_server=true)
E, [2020-03-23T03:33:52.900544 #10121-70334931321340] ERROR -- : Can't use Channel::Driver::Imap: #<OpenSSL::SSL::SSLError: SSL_connect returned=1 errno=0 state=error: dh key too small>
E, [2020-03-23T03:33:52.900608 #10121-70334931321340] ERROR -- : SSL_connect returned=1 errno=0 state=error: dh key too small (OpenSSL::SSL::SSLError)
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/net/protocol.rb:44:in `connect_nonblock'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/net/protocol.rb:44:in `ssl_socket_connect'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/net/imap.rb:1531:in `start_tls_session'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/net/imap.rb:1092:in `initialize'
/opt/zammad/app/models/channel/driver/imap.rb:107:in `new'
/opt/zammad/app/models/channel/driver/imap.rb:107:in `block in fetch'
/opt/zammad/app/models/channel/driver/imap.rb:517:in `block in timeout'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/timeout.rb:93:in `block in timeout'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/timeout.rb:33:in `block in catch'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/timeout.rb:33:in `catch'
/opt/zammad/vendor/ruby-2.5.5/lib/ruby/2.5.0/timeout.rb:108:in `timeout'
/opt/zammad/app/models/channel/driver/imap.rb:516:in `timeout'
/opt/zammad/app/models/channel/driver/imap.rb:106:in `fetch'
/opt/zammad/app/models/channel.rb:56:in `fetch'
/opt/zammad/vendor/bundle/ruby/2.5.0/gems/activerecord-5.2.4.1/lib/active_record/relation/delegation.rb:71:in `each'
/opt/zammad/app/models/channel.rb:30:in `fetch'
I cannot link my email account because the dh key is too small.
Does anyone have any idea how to solve the problem?
Thank you in advance.
Best regards Marc
