Used Zammad version: 6.3.0-1713783379.979314a7.bullseye
Operating system: Debian GNU/Linux 11 (bullseye)
Browser + version: any tested browser versions and operating-systems
We upgraded our zammad installation from zammad 6.2 to 6.3.
Everything worked well but images in Tickets (inserted via copy and paste) bevore Upgrade are not shown.
The used image url in the ticket-web-view hast the syntax: cid:97584.b1b1650a-b337-4681-806f-df57e1348d15@server.fqdn
New added images (inserted via copy and paste after upgrade) worked as expected.
Is there a way to reenable these old image-references ?
the command “sudo -u zammad zammad run rake zammad:searchindex:rebuild”
did not solve the problem.
I can revert the last update (restore snapshot before update) but the i will lose all tickts and changes of this day.
Do you have any suggestions to solve this problem or to find more information about whats happened / where the problem is located.
the system was installed in 2018_03 as Zammad Version 2.x with MySQL.
and migrated many times to new Debian Versions (with Backup and Restore) and migrated from MySQL to PostgreSQL.
Database -migration was done before zammad announced the migration Infos:
so I wrote my own (2021_10)
and here the output of the command
zammad run rails r "pp Store.where(\"o_id LIKE '%.0'\").count"
114844
I used the following grep to verify the output of the DRY-Run; maybe this helps other users
zammad run rails r fix_store_object_o_id_floats.rb | grep -v -E "Change store object [0-9]+ \((Ticket\:\:Article(|\:\:Mail)|Avatar\:\:User\:\:(Resize|Full)|System\:\:Logo|UploadCache)\) o_id from [0-9]+\.0 to [0-9]+"
I would run the PROD Mode after a Backup in the afternoon (after the rush hours)
and give you a update here.
for other users:
put zammad in maintenance mode
run the script (after checking the output from the dry run)
disable maintenance mode
reload browser - feeling lucky
