HTTP 400 error when trying to rebuild search index
Hi, I have installed Zammad using an Ansible role I’ve written (see the elastic search tasks in this role and also the elastic search role) and it all seems to work apart from the last rebuilding of the search index step.
  • Used Zammad version: stable
  • Used Zammad installation source: source
  • Operating system: Debian Buster
  • Search index rebuilt
drop indexes...done
create indexes...done
create pipeline (pipeline)... rake aborted!
Unable to process put request to elasticsearch URL 'http://localhost:9200/_ingest/pipeline/zammad258231011319'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x000055f8e682db08 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]}],\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]},\"status\":400}", @data=nil, @code="400", @content_type=nil, @error="Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!">
Payload:
{"description":"Extract zammad-attachment information from arrays","processors":[{"foreach":{"field":"article","processor":{"foreach":{"field":"_ingest._value.attachment","processor":{"attachment":{"target_field":"_ingest._value","field":"_ingest._value._content","ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}},{"foreach":{"field":"attachment","processor":{"attachment":{"target_field":"_ingest._value","field":"_ingest._value._content","ignore_failure":true,"ignore_missing":true}},"ignore_failure":true,"ignore_missing":true}}]}
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:927:in `make_request_and_validate'
/opt/zammad/lib/search_index_backend.rb:84:in `block (2 levels) in processors'
/opt/zammad/lib/search_index_backend.rb:68:in `each'
/opt/zammad/lib/search_index_backend.rb:68:in `block in processors'
/opt/zammad/lib/search_index_backend.rb:65:in `each'
/opt/zammad/lib/search_index_backend.rb:65:in `processors'
/opt/zammad/lib/tasks/search_index_es.rake:95:in `block (2 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:67:in `block (2 levels) in <main>'
/opt/zammad/lib/tasks/search_index_es.rake:177:in `block (2 levels) in <main>'
The results with --trace:
** Execute environment
** Invoke searchindex:configured (first_time)
** Execute searchindex:configured
** Execute searchindex:rebuild
** Execute searchindex:drop
drop indexes...done
** Execute searchindex:drop_pipeline
** Execute searchindex:create
** Execute searchindex:create_pipeline
Response:
#<UserAgent::Result:0x0000557cc36c9978 @success=false, @body="{\"error\":{\"root_cause\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]}],\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\",\"suppressed\":[{\"type\":\"parse_exception\",\"reason\":\"No processor type exists with name [attachment]\",\"processor_type\":\"foreach\"}]},\"status\":400}", @data=nil, @code="400", @content_type=nil, @error="Client Error: #<Net::HTTPBadRequest 400 Bad Request readbody=true>!">
Payload:
Payload size: 0M
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `block in execute'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `each'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:273:in `execute'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:214:in `block in invoke_with_call_chain'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/2.6.0/monitor.rb:235:in `mon_synchronize'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:194:in `invoke_with_call_chain'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/task.rb:183:in `invoke'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:160:in `invoke_task'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block (2 levels) in top_level'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `each'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:116:in `block in top_level'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:125:in `run_with_threads'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:110:in `top_level'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:83:in `block in run'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:186:in `standard_exception_handling'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/lib/rake/application.rb:80:in `run'
/opt/zammad/.rbenv/versions/2.6.6/lib/ruby/gems/2.6.0/gems/rake-12.3.3/exe/rake:27:in `<top (required)>'
/opt/zammad/.rbenv/versions/2.6.6/bin/rake:23:in `load'
/opt/zammad/.rbenv/versions/2.6.6/bin/rake:23:in `<main>'
su - zammad
export RAILS_ENV=production
rake searchindex:rebuild
I fear I might be missing something obvious here?
I was missing something, a restart appears to have been all that was needed.
