- Used Zammad version: 6.3.0
- Operating system: Windows
I expect to go into the zammad-railsserver-1 container.
Then run rails c (zammad rails c doesnt work)
and then i could run something like Ticket::State.all.pluck(:name)
in the railscontainer running rails c and getting error:
zammad@280a551a6fc1:~$ rails c
/usr/local/bundle/gems/railties-7.0.8.1/lib/rails/application/configuration.rb:352:in database_configuration': Cannot load database configuration: (RuntimeError) Could not load database configuration. No such file - ["config/database.yml"] from /usr/local/bundle/gems/activerecord-7.0.8.1/lib/active_record/railtie.rb:266:in
block (2 levels) in class:Railtie’
from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:95:in class_eval' from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:95:in
block in execute_hook’
from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:85:in with_execution_control' from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:90:in
execute_hook’
from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:60:in block in on_load' from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:59:in
each’
from /usr/local/bundle/gems/activesupport-7.0.8.1/lib/active_support/lazy_load_hooks.rb:59:in on_load' from /usr/local/bundle/gems/activerecord-7.0.8.1/lib/active_record/railtie.rb:262:in
block in class:Railtie’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/initializable.rb:32:in instance_exec' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/initializable.rb:32:in
run’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/initializable.rb:61:in block in run_initializers' from /usr/local/lib/ruby/3.2.0/tsort.rb:228:in
block in tsort_each’
from /usr/local/lib/ruby/3.2.0/tsort.rb:350:in block (2 levels) in each_strongly_connected_component' from /usr/local/lib/ruby/3.2.0/tsort.rb:431:in
each_strongly_connected_component_from’
from /usr/local/lib/ruby/3.2.0/tsort.rb:349:in block in each_strongly_connected_component' from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in
each’
from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in call' from /usr/local/lib/ruby/3.2.0/tsort.rb:347:in
each_strongly_connected_component’
from /usr/local/lib/ruby/3.2.0/tsort.rb:226:in tsort_each' from /usr/local/lib/ruby/3.2.0/tsort.rb:205:in
tsort_each’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/initializable.rb:60:in run_initializers' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/application.rb:372:in
initialize!’
from /opt/zammad/config/environment.rb:7:in <main>' from /usr/local/bundle/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in
require’
from /usr/local/bundle/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in require' from /usr/local/bundle/gems/zeitwerk-2.6.13/lib/zeitwerk/kernel.rb:34:in
require’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/application.rb:348:in require_environment!' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/command/actions.rb:28:in
require_environment!’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/command/actions.rb:15:in require_application_and_environment!' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/commands/console/console_command.rb:105:in
perform’
from /usr/local/bundle/gems/thor-1.3.1/lib/thor/command.rb:28:in run' from /usr/local/bundle/gems/thor-1.3.1/lib/thor/invocation.rb:127:in
invoke_command’
from /usr/local/bundle/gems/thor-1.3.1/lib/thor.rb:527:in dispatch' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/command/base.rb:87:in
perform’
from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/command.rb:48:in invoke' from /usr/local/bundle/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in
from /usr/local/bundle/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in require' from /usr/local/bundle/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in
require’
from bin/rails:5:in `’
I´m not sure if that is the way to go. I hope anyone could show me some assistance.
With the 6.2x version i could access rails c without error
