How to restore a deleted ticket state
  • Used Zammad version: 2.4.x
  • Used Zammad installation source: https://ftp.zammad.com/zammad-latest.tar.gz
  • Operating system: CentOs
  • Browser + version: Google Chrome, Version 66.0.3359.139 (Offizieller Build) (64-Bit)
We accidently deleted default ticket states ‘Pending reminder’ and ‘Pending close’ (Using rails console - Ticket::State.find(X).destroy)
Is there a way to restore the default ticket states?
Many thanks!
Ralf
I think @anon29869905 or @martini can help at that point.
Took a look into the admin documentation, but I think it’s missing especially those parts. :slight_smile:
You can run zammad run rails r db/seeds/ticket_states.rb
This will create each default state that doesn’t exist.
Many thanks Thorsten
I tried that, but seems there are some constraints. Got a lot of error messages, starting:
cheers
Ralf
Sorry for the delay. Please edit the file and add UserInfo.current_user_id = 1 in the first line. You can remove it afterwards.
Very often in the community it has been mentioned that there will be a UI in order to be able to change/add status. What’s the status here?
Many thanks and cheers
Ralf
