Used Zammad version: 3.1.0-1567098044.4a5edb77.jessie
Used Zammad installation source: deb from repository
Operating system: Debian 8.11
Browser + version: Firefox ESR 52.x
Question:
Is there a way to integrate pictures in knowledgebase articles? I’m not referring to attachments, but inline images which are shown within the text on the page
Use Case:
Many things are better explained by or with the help of images. Pure text is often not sufficient or not suited to explain e.g. the usage of graphical tools
Yup there is, altough at some points it might be a bit tricky.
Problem mostly is that you have to ensure to copy the images content, not the image (confusing I know).
How cute. I haven’t seen animated gifs for a long while . But thanks lot, that helped very much and works like a charm. It is initially slightly confusing as you say. Image integration might be a good extension for the editor … but only after we finally can create code-styled text .
