How to instructions for adding object attributes for AI Agents: ticket-categorizer and ticket-text-extractor
  • Used Zammad version: 7.1
  • Operating system: debian
  • Browser + version: Firefox 152
creating AI agent ticket extractor or AI agent ticket categorizer . see docs AI Agents — Zammad Admin Documentation documentation documentation should display step by step instructions and/or example screenshots for required settings to successfully enable ticket extractor or ticket categorizer . Zammad user expects simple steps, instructions, and/or screenshots to enable and properly configure AI agent with object attributes Objects — Zammad Admin Documentation documentation
configuring AI agent ticket extractor second setup config page shows red error box “No suitable object attributes found, please add one of the supported types first: input, textarea, integer, select, tree_select”
configuring AI agent categorizer second setup config page shows red error box : "No suitable object attributes found, please add one of the supported types first: select, multiselect, tree_select, multi_tree_select "
Zammad user confused how to configure page /#system/object_manager to match requirements on page /#ai/ai_agents
Documentation does not cover how-to setup object attributes for two AI agents: ticket text extractor and ticket categorizer
Documentation pages
Zammad with no new correctly created attribute objects
Not sure if I got you right. The text of both AI agents says clearly that an object attribute is required and even links to the object attribute section:
Categorizer:
Because there is no built in category field in Zammad, you first have to create a custom ticket attribute in which you want to track the ticket’s category. The field type must be one of the select types.
Text extractor:
Make sure to have a custom ticket attribute in which you want to store the extracted information. Otherwise, create a suitable > one before configuring the AI agent. The field type must be one of the following:
  • Text
  • Textarea
  • Integer
  • Single selection
  • Single tree selection
For select-type attributes, the wizard allows you to limit the options the AI agent can choose > from and to add descriptions for them. For these types, the AI agent also receives the list of > allowed options to choose from in case of a match.
And to avoid duplicate content, there are just links to the object attribute section.
At least for the categorizer agent, a scenario is that you already have a custom category field in which you track the categories manually.
