How to go on with installation and usage? I dont know
  • Used Zammad version: 6.3.1
  • Operating system: Ubuntu Server 24.04 VM (virtualized with Proxmox)
  • Browser + version: Opera / 113.0.5230.62
Hi Guys,
i’m new to setting up Zammad on a Ubuntu Server. I used the workaround from the docs of Zammad itself and made every step like in there. Requierements and installation worked fine, but then comes “Configuring The Webserver”. I replaced server_name “localhost” in /etc/nginx/sites-available/zammad.conf with “zammad.as-example.de” and “www.zammad.as-example.de”. I used nginx and got ssl certificate as recommended, but self-signed. As soon as i went on with “Adjusting the Webserver Configuration”, i don’t know how to go further with Step 2 - Adjust the config file. What is meant with adjusting directories of that 3 SSL certificates?
When i will entry the Website, there comes “Welcome to nginx!” and it says, it is successfully installed but further configuration is requiered. Yeah as i said, i dont know how to go further to get this work done. When you need additional information, please let me know.
Docs Link: Package Installation — Zammad System Documentation documentation
Sorry, I’m unable to follow at all.
The documentation is quite forward to follow so I don’t know which “point 3” (as example) you mean. There’s many of 3. in the documentation.
