- Used Zammad version: 6.1
- Operating system: Ubuntu 22.04
- Build the search index successfully
$ sudo zammad run rake zammad:searchindex:rebuild
- $ sudo zammad run rails r “Setting.set(‘es_url’, ‘
https://localhost:9200’)” - $ sudo zammad run rails r “Setting.set(‘es_user’, ‘myuser’)”
- $ sudo zammad run rails r “Setting.set(‘es_password’, ‘mypw’)”
- $ sudo zammad run rake zammad:searchindex:rebuild
rake aborted!
Unable to process GET request to elasticsearch URL 'https://localhost:9200'. Check the response and payload for detailed information:
Response:
#<UserAgent::Result:0x00007fce2a9f3f08 @success=false,
@body=nil, @data=nil, @code=0, @content_type=nil,
@error="#<OpenSSL::SSL::SSLError: SSL_connect returned=1 errno=0 peeraddr=127.0.0.1:9200 state=error: certificate verify failed (self-signed certificate in certificate chain)>",
@header=nil>
Payload:
null
Payload size: 0M
/opt/zammad/lib/search_index_backend.rb:36:in `info'
/opt/zammad/lib/tasks/zammad/search_index_es.rake:64:in `block (3 levels) in <main>'
/opt/zammad/vendor/bundle/ruby/3.1.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/opt/zammad/bin/bundle:121:in `load'
/opt/zammad/bin/bundle:121:in `<main>'
Tasks: TOP => zammad:searchindex:rebuild => zammad:searchindex:version_supported
- Follow the installation guide and install a fresh installation of elasticsearch and zammad. Change ‘es_url’ to ‘
https://localhost:9200’. Install SSL certs for the host using letsencrypt and certbot.
Dear Community
My question is: how can I fix the self-signed cert problem after the default elasticsearch installation? If I run sudo zammad run rails r "Setting.set('es_ssl_verify', false)" the command zammad run rake zammad:searchindex:rebuild works.
Kind regards
Nicolas
