How to edit system defined objects in zammad
  • Used Zammad version: 5.0.x
  • Used Zammad installation type: (source, package, docker-compose, …) Package
  • Operating system: Ubuntu 20.04 LTS
  • Browser + version: Chrome 96.0.4664.110 (Official Build) (64-bit)
  • I should able to edit system defined objects in Tickets, User, Organization & Group in System – Objects
  • I can edit objects only which objects I have created not that which are already available there by default after zammad installation.
You cannot edit default objects.
Especially the ones you’re talking about are technical references.
Our documentation also hints for that:
https://admin-docs.zammad.org/en/latest/system/objects.html#system-objects
