- Used Zammad version: 4.0
- Used Zammad installation type: repo centos 7
- Operating system: centos 7
- Browser + version: Firefox 78.9.0esr
I am seeing failed tasks under Current Status on the Monitoring page:
It is not relevant why they failed in the past.
- having a mean to remove this message from the monitoring, because I do not care anymore
- constantly showing this kind of old messages
we have the same problem.
I have found the problem and the Last task Finished Succesfully, but how to delete the failed Task?
maybe this thread is of any help?
Thanks for the link, but as far as I see this is not helpfull:
# zammad run rails c
Loading production environment (Rails 5.2.4.5)
irb(main):001:0> Delayed::Job.count
=> 0
irb(main):002:0> Delayed::Job.first
=> nil
irb(main):003:0> Delayed::Job.last
=> nil
maybe try it on the; DataPrivacyTask instead of Delayed?
this appears to be the code, that is reporting the stuck tasks;
maybe you can adopt it to delete the tasks
Yes, that was helpfull, thanks. I could remove the failed task with this command:
DataPrivacyTask.find(40).destroy
The id was displayed on the monitoring page in the backend.
system
Closed
8
