How to create PostgreSQL database?
I’m installing zammad 6.3.1 on Debian 12, via package.
I’ve already PostgreSQL up and running, but after the installation I don’t see the database zammad created, and the conf/database.yml looks fine:
$ sudo cat /opt/zammad/config/database.yml
production:
  adapter: postgresql
  database: zammad
  pool: 50
  timeout: 5000
  encoding: utf8
  username: zammad
  password: xyz
I’ve tried to run zammad reconfigure but no database is created.
If I run, as operating system zammad the command rake db:create I got a strange error:
$ ./bin/rake db:create
Could not find mysql2-0.5.6, pg-1.5.6, rszr-1.5.0, webauthn-3.1.0, openssl-3.2.0, cose-1.3.0, tpm-key_attestation-0.12.0, openssl-signature_algorithm-1.3.0 in locally installed gems
Run `bundle install --gemfile /opt/zammad/Gemfile` to install missing gems.
but then running bundle install fails spectacurarly:
$ ./bin/bundle install
Fetching gem metadata from https://rubygems.org/.......
Installing rszr 1.5.0 with native extensions
Installing mysql2 0.5.6 with native extensions
Installing openssl 3.2.0 with native extensions
Installing pg 1.5.6 with native extensions
Fetching openssl-signature_algorithm 1.3.0
Installing openssl-signature_algorithm 1.3.0
Fetching tpm-key_attestation 0.12.0
Fetching cose 1.3.0
Installing tpm-key_attestation 0.12.0
Installing cose 1.3.0
Gem::Ext::BuildError: ERROR: Failed to build gem native extension.
current directory:
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/gems/mysql2-0.5.6/ext/mysql2
/opt/zammad/vendor/ruby-3.2.4/bin/ruby extconf.rb
checking for rb_absint_size()... yes
checking for rb_absint_singlebit_p()... no
checking for rb_gc_mark_movable()... yes
checking for rb_wait_for_single_fd()... no
checking for rb_enc_interned_str() in ruby.h... no
*** extconf.rb failed ***
Could not create Makefile due to some reason, probably lack of necessary
libraries and/or headers.  Check the mkmf.log file for more details.  You may
need configuration options.
Provided configuration options:
        --with-opt-dir
        --without-opt-dir
        --with-opt-include
        --without-opt-include=${opt-dir}/include
        --with-opt-lib
        --without-opt-lib=${opt-dir}/lib
        --with-make-prog
        --without-make-prog
        --srcdir=.
        --curdir
        --ruby=/opt/zammad/vendor/ruby-3.2.4/bin/$(RUBY_BASE_NAME)
        --with-openssl-dir
        --without-openssl-dir
        --with-mysql-dir
        --without-mysql-dir
        --with-mysql-include
        --without-mysql-include=${mysql-dir}/include
        --with-mysql-lib
        --without-mysql-lib=${mysql-dir}/lib
        --with-mysql-config
        --without-mysql-config
        --with-mysqlclient-dir
        --without-mysqlclient-dir
        --with-mysqlclient-include
        --without-mysqlclient-include=${mysqlclient-dir}/include
        --with-mysqlclient-lib
        --without-mysqlclient-lib=${mysqlclient-dir}/lib
        --with-mysqlclientlib
        --without-mysqlclientlib
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/mkmf.rb:1083:in `block in find_library': undefined
method `split' for nil:NilClass (NoMethodError)
    paths = paths.flat_map {|path| path.split(File::PATH_SEPARATOR)}
        from /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/mkmf.rb:1083:in `each'
        from /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/mkmf.rb:1083:in `flat_map'
        from /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/mkmf.rb:1083:in `find_library'
        from extconf.rb:131:in `<main>'
To see why this extension failed to compile, please check the mkmf.log which can be found here:
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/extensions/x86_64-linux/3.2.0-static/mysql2-0.5.6/mkmf.log
extconf failed, exit code 1
Gem files will remain installed in
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/gems/mysql2-0.5.6 for inspection.
Results logged to
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/extensions/x86_64-linux/3.2.0-static/mysql2-0.5.6/gem_make.out
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/builder.rb:119:in `run'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/ext_conf_builder.rb:28:in `build'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/builder.rb:187:in `build_extension'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/builder.rb:221:in `block in
build_extensions'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/builder.rb:218:in `each'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/ext/builder.rb:218:in `build_extensions'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/rubygems/installer.rb:846:in `build_extensions'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/rubygems_gem_installer.rb:72:in
`build_extensions'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/rubygems_gem_installer.rb:28:in `install'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/source/rubygems.rb:202:in `install'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/installer/gem_installer.rb:54:in `install'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/installer/gem_installer.rb:16:in
`install_from_spec'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/installer/parallel_installer.rb:156:in
`do_install'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/installer/parallel_installer.rb:147:in `block
in worker_pool'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/worker.rb:62:in `apply_func'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/worker.rb:57:in `block in process_queue'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/worker.rb:54:in `loop'
  /opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/worker.rb:54:in `process_queue'
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/3.2.0/bundler/worker.rb:90:in `block (2 levels) in
create_threads'
An error occurred while installing mysql2 (0.5.6), and Bundler cannot continue.
In Gemfile:
  mysql2
    current directory: /opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/gems/rszr-1.5.0/ext/rszr
checking for Imlib2.h... no
imlib2 development headers are missing
        --with-opt-dir
        --without-opt-dir
        --with-opt-include
        --with-opt-lib
        --with-make-prog
        --without-make-prog
        --srcdir=.
        --curdir
        --with-imlib2-dir
        --without-imlib2-dir
        --with-imlib2-include
        --without-imlib2-include=${imlib2-dir}/include
        --with-imlib2-lib
        --without-imlib2-lib=${imlib2-dir}/lib
        --with-imlib2-config
        --without-imlib2-config
        --with-pkg-config
        --without-pkg-config
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/extensions/x86_64-linux/3.2.0-static/rszr-1.5.0/mkmf.log
Gem files will remain installed in /opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/gems/rszr-1.5.0
for inspection.
Results logged to
/opt/zammad/vendor/ruby-3.2.4/lib/ruby/gems/3.2.0/extensions/x86_64-linux/3.2.0-static/rszr-1.5.0/gem_make.out
build_extensions'
`build_extensions'
`install_from_spec'
`do_install'
in worker_pool'
create_threads'
An error occurred while installing rszr (1.5.0), and Bundler cannot continue.
In Gemfile:
  rszr
but I suspect I don’t need to get into this, and dependencies should be already installed.
Am I missing something?
While installing zammad, I got the following and a lot more similar errors:
# apt install zammad
# Clear cache...
rake aborted!
ActiveRecord::NoDatabaseError: We could not find your database: zammad. Which can be found in the database configuration file located at config/database.yml. (ActiveRecord::NoDatabaseError)
To resolve this issue:
- Did you create the database for this app, or delete it? You may need to create your database.
- Has the database name changed? Check your database.yml config has the correct database name.
To create your database, run:
        bin/rails db:create
Am I wrong but the package should create the database itself, or do I have to create it in advance?
I’ve tried to manually create the PostgreSQL database:
postgres=# create role zammad with login password '<the password from database.yml>';
postgres=# create database zammad with owner zammad;
and verified that the zammad operating system user can connect:
ammad@zammad-test:~$ id
uid=999(zammad) gid=996(zammad) gruppi=996(zammad)
zammad@zammad-test:~$ psql -c 'select current_date; ' zammad
 current_date
 2024-06-24
(1 riga)
With the database in place, things go a little better but the installation still complains:
== 20240612071836 CleanupObsoleteTranslations: migrating ======================
== 20240612071836 CleanupObsoleteTranslations: migrated (0.0004s) =============
# Updating translations...
/opt/zammad/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8.4/lib/active_record/connection_adapters/postgresql_adapter.rb:768:in `exec_params': PG::ForeignKeyViolation: ERROR:  insert or update on table "translations" violates foreign key constraint "fk_rails_d6e6d9635d" (ActiveRecord::InvalidForeignKey)
DETAIL:  Key (created_by_id)=(1) is not present in table "users".
Just for the record:
# apt search zammad
Ordinamento... Fatto
Ricerca sul testo... Fatto
zammad/sconosciuto,now 6.3.1-1719208095.8ca3e48a.bookworm amd64 [installato]
  Zammad is a web based open source helpdesk/customer support system
Seems I’ve solved the issue.
Not sure this is either a Debian or Zammad issue, but here is the problem.
After purging the package apt --purge remove zammad the directory /opt/zammad and the zammad PostgreSQL database remain in place.
Removing manually the database does not suffice:
% sudo -u postgres psql -c 'drop database zammad;'
% sudo -u postgres psql -c 'drop role zammad;'
and there is also the need to remove (after accurate backup) /opt/zammad.
Therefore, after having stopped the daemon, purged the package, removed the directory and the database, running a fresh install apt instlal zammad concludes with success creating the database.
We intentionally do not remove content so you don’t have an accidental data loss. You have to clean up yourself.
