We get some pdf or picture files from our customers which are larger than 8 MB. We have to add them to the tickets. Unfortunally we get a internal server error by uploading this files. Files smaller than 8 MB can be added without problems. The E-Mail max file size is now set to 40 MB. We dont use direct E-Mail import.
Internal Server Error by uploading files larger than 8 MB to tickets
Take a file larger than 8 MB and upload it. You will get this error.
How can we configure the max size in tickets? In this forum i haven’t found anything for that problem. The only thing i found was settings for the knowledgebase and e-mails. Because of that foundings i had set the value of max size in E-Mails to 40 MB instead of 10 MB, but it dont works for tickets…
thanks for your answer but we are using apache instead of nginx.
Is there an equivalent solution with apache? All i find belongs to php.ini, but we dont have a php.ini…
Well of course.
You don’t have a php.ini in Zammad context as Zammad doesn’t use PHP at all.
Please don’t get me wrong, but if you have to ask these kind of questions on this level already, selfhosting a Zammad installation may be a bit over your head. This might be a security issue.
