yene
July 6, 2021, 9:20am
#1
Dear Zammad,
It is possible to get tickets by number range with the following query:
https://…/api/v1/tickets/search?query=number:[25030 TO *]
Is it possible to get a similar ticket range by ID?
e.g.::
https://…/api/v1/tickets/search?query=id:[30 TO *]
Thank you for your time
yannick
Used Zammad version: 4.1.x
Used Zammad installation type: source
Operating system: linux
Hi @yene ,
i don’t think its possible to search for a range of ticket numbers at the moment, because it is indexed as text to make it searchable by wildcard search like “123*”. But it could be possible feature request to index it also as integer to make your case possible.
Ticket ids should be possible tho. Try this:
id:>=10 AND id:<20
= greater equal 10 and smaller than 20.
yene
July 6, 2021, 6:42pm
#3
Thank you for the quick answer, now search by id works.
Search for a range of ticket numbers works, but we will avoid it for now to not run into an edge case.
system
closed
November 4, 2021, 7:43am
#5
