Hi there,
i don’t have much experience with linux, nginx etc.
But I installed zammad for debian and it works great internally.
now I want to change the port, sorry for the stupid question, but how can I change the port from 80 to 8080.
in zammad.conf I have this entry, what do I have to change here?
thanks for the answer, but unfortunately it doesn’t work.
I changed the ports as described. got with “iptables -A INPUT -p tcp --dport 8080 -j ACCEPT”
registered.
but get this error message from the nginx
“nginx: [emerg] invalid port in” [::]: “of the” listen “directive in /etc/nginx/sites-enabled/zammad.conf:15”
it works if I delete the line “listen [::]: 8080;” !
where can I look where the error is?
