- Used Zammad version: 6.3.1
- Operating system: CentOS9
- Using apache2 (httpd on CentOS9) to host Zammad should work (given that when using NGINX it works, but using apache2 it doesn’t)
- Apache2 gives “Job for httpd.service failed because a timeout was exceeded”, nothing to be found why it times out in /var/logs/httpd/error.log or /opt/zammad/log/production.log
- The weird thing is that Zammad’s web interface is accessible for a minute or 2 and when httpd then gives error, the web interface is no more accessible
- Install Zammad as package
- Install ElasticSearch
- Stop Nginx service
- copy config file from /opt/zammad/contrib/apache2/zammad.conf to /etc/httpd/conf/httpd.conf
- add “Listen 80”, “User = apache, Group = apache” and required “LoadModules” to the config
- Start httpd service
