I am getting 100% CPU when running Zammad causing the server to be very slow.
Note that no other application is running beside Zammad.
Regards
Used Zammad version:
Please fill in the required information in the template you just skipped (e.g. Zammad-Version).
Also let us know what hardware specs you’re running Zammad on, meaning:
CPU cores (and speed)
guruanteed RAM of your server Zammad runs on/in
Storage (type e.g. SSD, HDD)
Another very useful information is what you’re doing in the moment the high cpu usuage appears (e.g. fetching many mails).
