Recently stumbled onto Zammad and thought I would give it a try. Having issues installing it though. I end up with a Welcome to NGINX page instead of Zammad page.
I have updated the server_name and tried with IP or FQDN, and neither work. I either get the welcome to nginx page or a 502 bad gateway.
Not sure what I’m missing. Any help will be greatly appreciated.
How do I check if zammad conf is enabled? Normally for nginx It would be the sites-available folder; however, that folder does not exist. Did I miss a step in the instructions?
Zammad is running and listening. I’ll have to check and see if something is blocking the ports.
I went through it and it appears that at some point during the initial install some items failed and I didn’t notice. I had to remove Zammad and install it again. This time spotting each error and correcting them. Not sure why it errored, but everything is good now.
