Help setting up S3 Storage / uninitialized constant Store::Provider::S3
  • Used Zammad version: 6.1.0-1701845240.5a81e629.buster
  • Operating system: Debian
I changed /config/storage.yml as follows:
amazon:
  service: S3
  access_key_id: redacted
  secret_access_key: redacted
  region: eu-central-1
  bucket: bucket name
restarted zammad
and selected S3 as Storage mode from the web UI settings
  • Attachments are saved to the S3 bucket
  • Error pops up “file cannot be uploaded”
  • zammad run rails r 'Rails.logger = Logger.new(STDOUT); pp Store::Provider::S3.ping?'
    fails with
Can anybody help me understand what’s going on? Thanks!
Hi @dwehrmann. Please make sure to read the S3 part in the documentation.
Hi @fliebe92
Actually, I did and I followed the steps.
Did you see anything I missed? If you are referring to the key “amazon”, I also tried “s3” as indicated in the docs. Made no difference.
Thanks!
Hi @dwehrmann,
the file path is config/zammad/storage.yml.
s3:
  endpoint: https://s3.eu-central-1.amazonaws.com
  bucket: bucket name
You can check the validity via the console.
In the case of package installation.
You also have to provide an endpoint in the config. This is needed because we support any S3-compatible service. See the following link for the Amazon region endpoints, Amazon Simple Storage Service endpoints and quotas - AWS General Reference
Hi @tschaefer
Thank you! I am lost about the file path, I think that’s the problem I’m running into:
I saw a storage.yml in /opt/zammad/config/– but obviously that is not correct.
I do not have a zammad dir in /opt/zammad/config/
From the docs, I assumed this was located in the zammad installation directory /opt/zammad/– is that wrong?
2023-12-08-132252_551x78_scrot
:wink:
The file config/storage.yml is the Rails default file, we never used it. Maybe we’ll remove it to avoid confusion.
Ah, I see, you’re still on Zammad 6.1, you need Zammad 6.2. The S3 storage is not available in 6.1.
AH! :slight_smile: That explains everything. Thank you!
