- Used Zammad version: 3.x
- Used Zammad installation source: docker
- Operating system: ubuntu 20
Hi.
I installed Zammad some time ago with Docker, and I’d now like to move my installation to an officially supported deployment. I installed a new Ubuntu 20.04 server and I’m attempting a double jump, for both version and arch.
I installed a clear zammad on the new server, then restored the last Docker backup, restored database.yaml
and restarted Zammad (manually), after apt install --reinstall
. While it appears to run all the database migrations after a couple of minutes I see no big issue in logs but rails service isn’t started. I see no error in the logs but port 3000 isn’t open…
Rails process is running in ps
zammad 1350574 128 0.2 145376 90532 ? Rs 08:25 0:01 script/rails server -b 127.0.0.1 -p 3000
I thought this could be the best method but it’s not working. Any suggestion on how to make the move?
thanks
