- Used Zammad version: helm chart 10.0.0 (zammad latest 6.x)
- Used Zammad installation type: (source, package, docker-compose, …) helm
- Operating system: k8s
- Browser + version: -
Clean install and restore from backup dump
Clean Install without any issues, but problems with restoring (official documentations doesn’t help me)
- connect to railserver container inside pod.
- upload dump to shared mount /opt/zammad/storage
- mv config.dist config
- update backup location
- update db adapter in database.yaml
~/contrib/backup$ ./zammad_db_user_helper.sh
# This helper script sets the current Zammad user password on your postgresql server.
# WARNING: THIS SCRIPT CHANGES CREDENTIALS, DO NOT CONTINUE IF YOU DON'T KNOW WHAT YOU'RE DOING!
Limitations:
- only works for local postgresql installations
- only works for postgresql
Enter 'yes' if you want to proceed!
ALTER zammad users password?: yes
# Stopping Zammad
zammad: unrecognized service
# WARNING: You don't seem to have administrative permissions!
#-> This may be fine if you're on a source code installation.
#-> Please ensure that Zammad is NOT running - otherwise restore will FAIL.
# Found an empty password - I'll be fixing this for you ...
# ... Fixing permission database.yml
You don't seem to be using a local PostgreSQL installation.
This script does not support your installation. No changes were done.
# Starting Zammad
then i run restore script
~/contrib/backup$ ./zammad_restore.sh
# Zammad restore started - Fri Sep 29 15:07:41 UTC 2023!
The restore will delete your current database!
Be sure to have a backup available!
Please ensure to have twice the storage of the uncompressed backup size!
Note that the restoration USUALLY requires root permissions as services are stopped!
Restore?: yes
Enter file date to restore:
20230917171046
File date: 20230917171046
Enter db date to restore:
20230917171046
DB date: 20230917171046
# Stopping Zammad
# Restoring Files
tar: opt/zammad/tmp: Cannot utime: Operation not permitted
tar: opt/zammad/tmp: Cannot change mode to rwxr-xr-x: Operation not permitted
tar: Exiting with failure status due to previous errors
# ERROR(2) - File restore reported an error.
- Check file permissions, and ensure Zammad IS NOT running, and try again.
# RESTORE WAS NOT SUCCESSFUL
type or paste code here
i tried on different containers (nginx, scheduler, websocket) but same issues.
If someone have solution with restoring in helm please give me correct way.
