Gitlab Integration
  • Used Zammad version: 3.2.x
  • Used Zammad installation source: (source, package, …): docker-compose
  • Operating system: Linux / Mac
  • Browser + version: Chrome 78
on Zammad 3.0 i have no Problems with gitlab
  • Redirect to my GitLab Installation
@anon29869905 thx for your help
40
@monotek - can you please point me to the nginx configuration of our docker-compose image? I think this issue somehow affects the docker-compose setup as well…
Hey @cyberrranger - is there any other service in front of your NGINX that handles SSL for you? Like a loadbalancer, proxy, application firewall etc. ?
@anon29869905 i use an nginx in front off GitHub - zammad/zammad-docker-compose: Zammad Docker images for docker-compose with this settings:
upstream ticket2-****-websocket {
server 172.17.0.1:8101;
upstream ticket2-****{
server 172.17.0.1:8100;
server {
listen 443 ssl;
server_name ticket2.****;
    ssl_certificate /etc/nginx/ssl/****.crt.pem;
    ssl_certificate_key /etc/nginx/ssl/****.key.pem;
    location /ws {
            proxy_http_version 1.1;
            proxy_read_timeout 86400;
            proxy_pass http://ticket2-****-websocket;
    location / {
            proxy_read_timeout 180;
            proxy_pass http://ticket2-****;
            gzip on;
            gzip_proxied any;
server {
listen 80;
    location / {
            return 301 https://ticket2.****/;
I guess that’s the thing. I assume that the HTTPS protocol information is somehow not passed to the zammad-nginx. Usually it should. It uses the default nginx config which passes the proto to the application. Please SSH into the zammad-nginx container and change the proxy_set_header X-Forwarded-Proto $scheme; lines to proxy_set_header X-Forwarded-Proto https;.
I will check in the next few days and then report me again, you certainly mean SSL and not SSH or?
I mean connect into the container to be able to configure the internal config of that NGINX.
