this is about the gitlab integration.
i have a lot of tickets where i have linked to gitlab issues. unfortunately, i have moved some of my gitlab repos to reorganize the structure. now the links in zammad do not work anymore. is there a common method to fix this. if there is no work around: can anybody tell me where the links are stored (in the database (which table) or something else)
Hi @borg1310. You have to fix it manually by using the Zammad GUI, in the same way the GitLab issue was added to the ticket. I do not recommend doing it in the database.
thanks for your reply.
i have thousands of tickets with links to gitlab. the reason why i want to know the table in zammads db is that without the old link i can not find the gitlab issue again.
