Receive a notice that a particular Github API is going to be deprecated soon:
Hello there!
On February 14th, 2020 at 08:44 (UTC) your application (zammad-login) used an access token (with the User-Agent Faraday v0.15.4) as part of a query parameter to access an endpoint through the GitHub API.
I’ve been checking that one with a current 3.2.
The answer is no.
Please note that this is out of the Zammad scope itself and depends on the omniauth-github gem.
I’ve been seaching a bit, it doesn’t seem to be adressed in upstream gem as well yet:
Edit:
Please note that 2.10 is a develop version of Zammad and also fairly old by now. You should consider upgrading.
