Hello there! I’m having problems trying to login using the Generic Oauth2 option. It’s seems that no user information is reaching zammad, therefore the user can’t be created.
I already tried sending login, email, firstname, etc. as reponse from the /ouath/token endpoint.
An example response payload will be appreciated. Regards!
- Infos:
Used Zammad version: 2.5.x
- Expected behavior:
To login
422: The change you wanted was rejected.
‘Minimum one identifier (login, firstname, lastname, phone or email) for user is required.’
