Please ensure your elasticsearch is running and the index is current.
Please provide your elasticsearch’s version.
Running : curl -XGET ‘localhost:9200’ gives me the following lines:
“name” : “node-1”,
“cluster_name” : “zammad”,
“cluster_uuid” : “jWTBzMfGRyGM0nqFDBiDyg”,
“version” : {
“number” : “7.6.0”,
“build_flavor” : “default”,
“build_type” : “deb”,
“build_hash” : “7f634e9f44834fbc12724506cc1da681b0c3b1e3”,
“build_date” : “2020-02-06T00:09:00.449973Z”,
“build_snapshot” : false,
“lucene_version” : “8.4.0”,
“minimum_wire_compatibility_version” : “6.8.0”,
“minimum_index_compatibility_version” : “6.0.0-beta1”
“tagline” : “You Know, for Search”
So elasticsearch is currently running on version 7.6.0
Please downgrade your Elasticsearch to ES 7.5.x.
ES 7.6.x is not even 7 days old and not yet supported or rather seems to bring issues.
If you still want to try, you might want to ensure your index is up to date and working:
I think new users and testing zammad from fresh installed facing that problem because they only followed the documentation how to install zammad and elasticsearch.
I Suggest to have option or notes how to install elasticsearch 7.5.x version in our documentation
Thank You
Thanks for the Information, but how can I install zammad with Elasticsearch Version 7.5.X?
And could you make a list of all dependencies that zammad needs with the currently working version.
Thank you
apt install elasticsearch=7.5.0 …?
