Freely definable variable
I need a freely definable variable for my trigger.
e.g. #{config.custom.foo}
This variable should be able to be set with an environment variable. It is not necessary in the web frontend.
Since I control all triggers from my CICD, I want to be able to adapt trigger texts to the respective environment (testing, staging, production) programmatically.
this is a trigger text on the instance #{config.custom.instance} with the URL #{config.fqdn}!
should be set (when config.custom.instance=production)
this is a trigger text on the instance production zammad.example.com!
Please make sure to use the categories template. Thank you.
