For Dummies - Simpe GUI for monitoring Zammad status
Very simple, based on ChatGPT code script to display Health status of two Zammad instances.
Just put your heath url inside ZHealth_support.py and enjoy big green (or red) square with current error.
Save this as ZHealth_support.py
#! /usr/bin/env python3
#  -*- coding: utf-8 -*-
# Support module generated by PAGE version 8.0
#  in conjunction with Tcl version 8.6
#    Jan 29, 2024 11:11:36 AM EET  platform: Windows NT
import sys
import tkinter as tk
import tkinter.ttk as ttk
from tkinter.constants import *
import requests
import json
import time
import ZHealth
_debug = True # False to eliminate debug printing from callback functions.
def poll_api():
# Replace the URLs below with the URLs of the REST APIs you want to poll
    url1 = "https://XXXXXXXXXXXX/api/v1/monitoring/health_check?token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    url2 = "https://YYYYYYYYYYYY/api/v1/monitoring/health_check?token=XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX"
    response1 = requests.get(url1)
    response2 = requests.get(url2)
    data1 = json.loads(response1.text)
    data2 = json.loads(response2.text)
    # Check if the 'healthy' key in the JSON string is True for both APIs
    if data1["healthy"] and data2["healthy"]:
        # If healthy is True for both APIs, fill Indicators with GREEN #00ff00 and set Messages clear.
        _w1.Indicator1.configure(background="#00ff00")
        _w1.Message1.configure(text='''NO ERROR right now''')
        _w1.Indicator2.configure(background="#00ff00")
        _w1.Message2.configure(text='''NO ERROR right now''')
    else:
        # If healthy is False for either API, print the 'issues' value for that API, set the color to Red #ff0000 and write Error message
        if not data1["healthy"]:
            # print("Helpdesk ERROR: {}".format(data1["issues"]))
            _w1.Indicator1.configure(background="#ff0000")
            _w1.Message1.configure(text=data1["issues"])
        else:
        if not data2["healthy"]:
            # print("Support ERROR: {}".format(data2["issues"]))
            _w1.Indicator2.configure(background="#ff0000")
            _w1.Message2.configure(text=data2["issues"])
        else:
# Wait for 15 seconds before polling again
    root.after(15000, poll_api)
def main(*args):
    '''Main entry point for the application.'''
    global root
    root = tk.Tk()
    root.protocol( 'WM_DELETE_WINDOW' , root.destroy)
    # Creates a toplevel widget.
    global _top1, _w1
    _top1 = root
    _w1 = ZHealth.Toplevel1(_top1)
    # Start polling the APIs
    poll_api()
    root.mainloop()
if __name__ == '__main__':
    ZHealth.start_up()
And second script are GUI design, save it as ZHealth.py
# GUI module generated by PAGE version 8.0
#    Jan 29, 2024 11:27:10 AM EET  platform: Windows NT
import sys
import os.path
_location = os.path.dirname(__file__)
import ZHealth_support
_bgcolor = '#d9d9d9'
_fgcolor = '#000000'
_tabfg1 = 'black'
_tabfg2 = 'white'
_bgmode = 'light'
_tabbg1 = '#d9d9d9'
_tabbg2 = 'gray40'
_style_code_ran = 0
def _style_code():
    global _style_code_ran
    if _style_code_ran: return
    try: ZHealth_support.root.tk.call('source',
                os.path.join(_location, 'themes', 'default.tcl'))
    except: pass
    style = ttk.Style()
    style.theme_use('default')
    style.configure('.', font = "TkDefaultFont")
    if sys.platform == "win32":
       style.theme_use('winnative')
    _style_code_ran = 1
class Toplevel1:
    def __init__(self, top=None):
        '''This class configures and populates the toplevel window.
           top is the toplevel containing window.'''
        top.geometry("600x450+390+190")
        top.minsize(120, 1)
        top.maxsize(1924, 1061)
        top.resizable(1,  1)
        top.title("Toplevel 0")
        top.configure(background="#d9d9d9")
        top.configure(highlightbackground="#d9d9d9")
        top.configure(highlightcolor="#000000")
        self.top = top
        _style_code()
        self.TSeparator1 = ttk.Separator(self.top)
        self.TSeparator1.place(relx=0.483, rely=0.0,  relheight=0.956)
        self.TSeparator1.configure(orient="vertical")
        self.Indicator2 = tk.Canvas(self.top)
        self.Indicator2.place(relx=0.583, rely=0.2, relheight=0.318
                , relwidth=0.288)
        self.Indicator2.configure(background="#00ff00")
        self.Indicator2.configure(borderwidth="4")
        self.Indicator2.configure(highlightbackground="#d9d9d9")
        self.Indicator2.configure(highlightcolor="#000000")
        self.Indicator2.configure(insertbackground="#000000")
        self.Indicator2.configure(relief="ridge")
        self.Indicator2.configure(selectbackground="#d9d9d9")
        self.Indicator2.configure(selectforeground="#000000")
        self.TLabel1 = ttk.Label(self.top)
        self.TLabel1.place(relx=0.033, rely=0.044, height=47, width=244)
        self.TLabel1.configure(foreground="#0000ff")
        self.TLabel1.configure(font="-family {Segoe UI} -size 12")
        self.TLabel1.configure(relief="flat")
        self.TLabel1.configure(anchor='center')
        self.TLabel1.configure(justify='center')
        self.TLabel1.configure(text='''Portal: ZAMMAD1 (internal)''')
        self.TLabel1.configure(compound='center')
        self.Indicator1 = tk.Canvas(self.top)
        self.Indicator1.place(relx=0.1, rely=0.2, relheight=0.318
                , relwidth=0.288)
        self.Indicator1.configure(background="#00ff00")
        self.Indicator1.configure(borderwidth="4")
        self.Indicator1.configure(highlightbackground="#d9d9d9")
        self.Indicator1.configure(highlightcolor="#000000")
        self.Indicator1.configure(insertbackground="#000000")
        self.Indicator1.configure(relief="ridge")
        self.Indicator1.configure(selectbackground="#d9d9d9")
        self.Indicator1.configure(selectforeground="black")
        self.TLabel1_1 = ttk.Label(self.top)
        self.TLabel1_1.place(relx=0.517, rely=0.044, height=47, width=244)
        self.TLabel1_1.configure(foreground="#0000ff")
        self.TLabel1_1.configure(font="-family {Segoe UI} -size 12")
        self.TLabel1_1.configure(relief="flat")
        self.TLabel1_1.configure(anchor='center')
        self.TLabel1_1.configure(justify='center')
        self.TLabel1_1.configure(text='''Portal: ZAMMAD2 (external)''')
        self.TLabel1_1.configure(compound='center')
        self.Message2 = tk.Label(self.top)
        self.Message2.place(relx=0.55, rely=0.622, height=111, width=224)
        self.Message2.configure(activebackground="#d9d9d9")
        self.Message2.configure(activeforeground="black")
        self.Message2.configure(anchor='nw')
        self.Message2.configure(background="#d9d9d9")
        self.Message2.configure(compound='left')
        self.Message2.configure(disabledforeground="#a3a3a3")
        self.Message2.configure(font="-family {Segoe UI} -size 9")
        self.Message2.configure(foreground="#000000")
        self.Message2.configure(highlightbackground="#d9d9d9")
        self.Message2.configure(highlightcolor="#000000")
        self.Message2.configure(justify='left')
        self.Message2.configure(text='''No ERROR right now''')
        self.Message2.configure(wraplength="224")
        self.Message1 = tk.Label(self.top)
        self.Message1.place(relx=0.067, rely=0.622, height=111, width=224)
        self.Message1.configure(activebackground="#d9d9d9")
        self.Message1.configure(activeforeground="black")
        self.Message1.configure(anchor='nw')
        self.Message1.configure(background="#d9d9d9")
        self.Message1.configure(compound='left')
        self.Message1.configure(disabledforeground="#a3a3a3")
        self.Message1.configure(font="-family {Segoe UI} -size 9")
        self.Message1.configure(foreground="#000000")
        self.Message1.configure(highlightbackground="#d9d9d9")
        self.Message1.configure(highlightcolor="#000000")
        self.Message1.configure(text='''No ERROR right now''')
        self.Message1.configure(wraplength="224")
def start_up():
    ZHealth_support.main()
