Used Zammad version: 3.1.0 (latest version)
Used Zammad installation source: source
Operating system: Ubuntu 18.04
Browser + version: all
We have created a few KB entries and set them to internal for visibility.
From the KB entry, I can link a ticket.
But if i want to link a KB entry from a ticket in the request answer field, the search symbol appears briefly and nothing happens after that.
If I enter only one keyword and press ENTER, at the top “no such object” appears .
I have already set the visibility to public, but that was’nt the trick.
Do we have to start an idexing or anything else?
thx for help
Andreas
Normally the searchindex will be updated automatically.
If this issue appears since updating from 3.0.x to 3.1.x, please rebuild your index with:
rake searchindex:rebuild
If this is a fresh install, you might want to ensure that your background jobs are fine:
rails r 'p Delayed::Job.count < this should be near to 0!
If rebuilding fails, ensure your elasticsearch service is working.
that doesn’t fix the problem. Index rebuild looks like this
if we use ?? in the Ticket, then KB-entry will be displayed.
However, if we try to search for “related answers” on the right side, no result is displayed.
Incidentally, we have updated directly from 2.9.0 to 3.1.0.
Hey Andreas,
thank you very much for clarifying the problem!
I’m afraid, you found a bug!
I already filled a bug report for you.
Let’s hope for a soonish fix
opened 02:24PM - 23 Aug 19 UTC
closed 07:50AM - 30 Oct 19 UTC
duplicate
Please post:
- Feature requests
- Development questions
- Technical questions
### Infos:
* Used Zammad version: 3.1
* Installation method (source, package, ..): any
* Operating system: any
* Database + version: any
* Elasticsearch version: any
* Browser + version: latest Google Chrome, latest Firefox
* This bug has originally found by the user `bendergruppe` on the Community: https://community.zammad.org/t/find-knowledge-base-entry-from-ticket/2973
### Expected behavior:
When linking an KB-Answer to a ticket (from ticket to answer), you can search for your answer and then simply link it.
### Actual behavior:
When linking an KB-Answer to a ticket (from ticket to answer), the UI does not provide a selection for found answers. Logfile and developer console clearly show that there have been results, they "simply" don't show up within the UI.
* create an knowledgebase answer
* ensure your searchindex is up to date
* go to any ticket (if none is available, create one)
* now try to link an answer to the ticket, by searching for a word that appears within the KB-Answer
### Screencast:
Hey @bendergruppe ! I just wanted to let you know that we found and fixed the issue via https://github.com/zammad/zammad/commit/d4afb0e8679cff6f343d574527aaeb0c75668627
We won’t do a stable backport but we will release a new stable version soon.
system
Closed
February 27, 2020, 7:52am
6
