Feature Request // Accounted Time Filter For Overviews
We use Overviews to see how much billable hours a client already stacked up.
For most clients we have a unique overview. The rest uses one without clients with unique ones.
In all cases there are tickets with no accounted time. Would be nice to have a filter option with accounted time.
Also the option to generate a Overview for the client with for example all Tickets that have >=1h hour accounted time would be nice.
Any opinions on that matter?
Thx,
Sebastian
We have an issue for that, currently only internally:
Enhance overviews: add “accounted time” to conditions · Issue #58 · zammad/coordination-private-features (github.com)
I gave your FR a “like”; others that support this FR should do the same. (as always).
Operators should be at least:
  • is set
  • is not set
  • greater than
  • greater or equal than
  • lower than
  • lower or equal than
And separated filter options for the activity types, if enabled.
Hm - can’t access the private FR, but I’d love to see this, too …
