Fatal error when git checkout
Yesterday i began to upgrade my selfhosted zammad instance from 5.1.x. But i ran into a problem and wanted to beginn from scratch with the latest backup.
Today i ran into a earlier problem.
I used this updatedinstructions:
  • Used Zammad version: 5.1.x
  • Operating system: debian 10.13
  • Browser + version: Firefox 119.1
the command: git checkout cd424e98689b8dc49878a37b9aab67192c36fd24
should download all nessecarry files to update zammad to 5.2.3 included Postgresql and Elasticsearch upgrade
when i enter the command: git checkout cd424e98689b8dc49878a37b9aab67192c36fd24
I get fatal: reference is not a tree: cd424e98689b8dc49878a37b9aab67192c36fd24
  1. open terminal
  2. connect to docker host
  3. change into zammads folder where all the docker-compose files are
  4. enter ā€˜git checkout cd424e98689b8dc49878a37b9aab67192c36fd24’
hello,
is there really no one, who can tell me how to update my zammad instance from 5.1.x to the latest build? the docs are lacking of that since the ā€œgit checkoutā€ command isn’t working anymore.
is there another way to update?
Primarily i think the Database- and Elasticsearchupdate is the problem why i cannot update to a newer build.
regards
hello,
how can i update my selfhosted instance from 5.1.x to the current version when the git checkout command is not working anymore?
Hi @luts. What happens if you do a git status? Is git pull working?
hello fliebe92,
and thanks for yor reply.
As doumented in the Upgrade-Documentation i used the branch there first.
git status <the branch i would like to pull> is giving me this output.
git status cd424e98689b8dc49878a37b9aab67192c36fd24
On branch master
Your branch is up to date with 'origin/master'.
nothing to commit, working tree clean
and git status gives me this:
git status
On branch master
Changes not staged for commit:
  (use "git add/rm <file>..." to update what will be committed)
  (use "git checkout -- <file>..." to discard changes in working directory)
        modified:   .env
        modified:   .examples/proxy/docker-compose.proxy-example.yml
        modified:   .examples/proxy/docker-compose.yml
        modified:   .github/docker-image-build.sh
        modified:   .github/linters/.markdown-lint.yml
        modified:   .github/stale.yml
        modified:   .github/workflows/ci-remote-image.yaml
        modified:   .github/workflows/ci.yaml
        deleted:    Dockerfile
        modified:   README.md
        deleted:    containers/zammad-elasticsearch/Dockerfile
        deleted:    containers/zammad-postgresql/Dockerfile
        deleted:    containers/zammad-postgresql/backup.sh
        modified:   containers/zammad/Dockerfile
        modified:   containers/zammad/docker-entrypoint.sh
        modified:   containers/zammad/setup.sh
        modified:   docker-compose.override-local.yml
        modified:   docker-compose.override.yml
        modified:   rancher-compose.yml
Untracked files:
  (use "git add <file>..." to include in what will be committed)
        .github/dependabot.yml
        scripts/
no changes added to commit (use "git add" and/or "git commit -a")
git pull, pulls the resent release, when i delete the files i changed.
Does this say you something?
In the meantime i have tryed to update my instance step by step an got stuck at version 5.4.1. So i had to restore from a backup but now i get some errors when i start the containers with the last funktioning backup.
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/graphql-config/node_modules/cosmiconfig/node_modules/.bin/js-yaml" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/gray-matter/node_modules/.bin/js-yaml" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/gray-matter/node_modules/js-yaml/node_modules/.bin/esparse" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/gray-matter/node_modules/js-yaml/node_modules/.bin/esvalidate" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/.bin/jiti" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/.bin/markdown-it" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/.bin/vite" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/.bin/vite-node" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/jsdom/node_modules/.bin/acorn" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/jsdom/node_modules/.bin/escodegen" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/histoire/node_modules/jsdom/node_modules/.bin/esgenerate" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/invariant/node_modules/.bin/loose-envify" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/js-beautify/node_modules/.bin/editorconfig" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/js-beautify/node_modules/.bin/nopt" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/jsdom/node_modules/.bin/acorn" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/jsdom/node_modules/.bin/escodegen" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/jsdom/node_modules/.bin/esgenerate" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/jsonwebtoken/node_modules/.bin/semver" failed: Operation not permitted (1)
zammad-init-1           | rsync: [generator] chgrp "/opt/zammad/node_modules/markdown-it-anchor/node_modules/.bin/markdown-it" failed: Operation not permitted (1)
Any ideas how to solve this?
I restored the backup from a tar-ball. I think the privileges are the same as bevor. So why ā€œOperation not permittedā€
Its frustrating…
So thanks for any help.
