Used Zammad installation source: (source, package, …) rpm
Operating system: centos 7
Browser + version: mozilla firefox 71.0
no errors are displayed under monitoring tab
this error is displayed:
Failed to run scheduled job ‘Execute jobs’. Cause: Failed to run Job.run after 10 tries #<RuntimeError: Use current_user.id in selector, but no current_user is set {“operator”=>“is”, “pre_condition”=>“current_user.id”, “value”=>"", “value_completion”=>""}>
I dont have any problems with that till now. But do I have to change something in my configuration or can I just ignore that message?
Could it be that a change in db/migrate/20190408000001_issue_2541_fix_notification_email_without_body.rb is responsible for that?
I had to change to a current user to migrate my database a few months ago
No, that shouldn’t be the case, as this migration only adds - to empty bodies to ensure they are not empty (and that the migration does not block the upgrade).
As I said, I am sure that you have a Scheduler Job that handles “current user IDs” and am curious about it’s configuration.
