Failed emails - RecordNotUnique / RecordInvalid when processing emails from existing users
Used Zammad version: 7.0.1-1777022007.52a7fc39.noble
Operating system: Ubuntu Noble (24.04)
Browser + version: Brave 1.91.168 (Official Build) (64-bit) Chromium: 149.0.7827.54
Infrastructure:
  • Zammad application — dedicated server
  • PostgreSQL 16.14 — dedicated server
  • Elasticsearch 8.19.15 — dedicated server
  • When an email arrives from a user that already exists in the database, Zammad should find the existing user and process the email normally, creating a ticket as expected.
  • Email ends up in FailedEmail table with one of two errors:
PG::UniqueViolation: duplicate key value violates unique constraint "index_users_on_login"
DETAIL: Key (lower(login::text))=(user@example.com) already exists.
ActiveRecord::RecordInvalid: Validation failed:
Email address 'user@example.com' is already used for another user.,
Login has already been taken
  • Requires manual cleanup via Rails console each time it occurs.
  • Email arrives from a user that already exists in the database
  • Zammad attempts to create the user instead of finding the existing one
  • Email processing fails and lands in FailedEmail table
And those users were created how before?
You’re not fiddling directly in Zammads database are you…?
Hi, the users were not in the database before this ticket.
And no we are not accesing or doing changes on the DB directly.
I have looked over the documentation, and I will change the setting ZAMMAD_PROCESS_DELAYED_COMMUNICATION_INBOUND_JOBS_WORKERS
this is right now set to 3, and I am suspecting on this to be the problem.
Even if this is the problem, why would the system still look for the ticketing creation process if the ticket has been created.
That might be a good catch. How many email accounts to you have connected?
Might be a race condition. Shouldn’t happen, but who knows. Kinda might depend on the answer of my above question. I did test this feature during my 7.0 release video, but with a fitting amount of email channels and didn’t have problems.
That being said, it doesn’t mean there might be no problem.
Right now we are on 16 emails integrated with IMAP in the system.
Priror to this problem we didn’t have problems when the setting was set to 3 workers. I changed the setting to 1, and we are not having any issues so far. weekly we would get 10-15 failed emails before change.
We didn’t touch the database directly, also to avoid any kind of DB optimization we transferd to storage to Filesystem, since we get around 700-900 tickets daily.
